PC-Experience » Hardware Reviews : » Reviews : » Tabellenübersicht der getesteten Netzteile von 2005 bis... » Hello Guest [Login|Register]
Go to the bottom of this page Tabellenübersicht der getesteten Netzteile von 2005 bis...
Achtung Tabellenübersicht der getesteten Netzteile von 2005 bis... Reply to this Post Post Reply with Quote Edit/Delete Posts Report Post to a Moderator       Go to the top of this page
- Update 26.02.2013 -
Netzteil Ø Spannungswerte max. Effizienz Temp 20% Last Temp Vollast
Antec High Current Gamer 400Watt 3,26V 4,94V 12,09V 88,3% 32,1° 40,2°
Arctic Cooling Fusion 550R 500 Watt 3,27V 5,02V 12,02V 87% 35,5° 53,5°
be quiet! Straight Power E8 400 Watt 3,32V 5,09V 12,08V 90,1% 33,6° 44,9°
be quiet! Straight Power E9 400 Watt 3,31V 5,04V 12,14V 93,6% 33,1° 41,4°
be quiet! P8 Dark Power Pro 750Watt 3,25V 4,95V 11,88V 90,9% 31,9° 39,3°
be quiet! P10 Dark Power Pro 550Watt 3,29V 4,99V 12,06V 93,7% 28,6° 41,3°
Compucase Cougar 700CM 700Watt 3,27V 5,03V 12,08V 88% 32° 43,5°
Compucase Cougar S700 700Watt 3,30V 5,01V 12,07V 90,5% 29,5° 41,5°
Compucase Cougar SE400 400Watt 3,26V 4,94V 12,08V 88,4% 33,6° 41,9°
Cooler Master Silent Pro M-Series 600Watt 3,36V 4,90V 12,16V 87% 33,5° 44,5°
Corsair AX850 850Watt 3,33V 5,01V 12,08V 92,9% 37,1° 40,1°
Corsair CX400W 400Watt 3,30V 4,88V 12,01V 85,5% 33,5° 43°
Corsair HX450W 450Watt 3,28V 4,93V 12,03V 86% 33,5° 43,5°
Corsair HX650W 650Watt 3,31V 4,93V 11,99V 87% 31,5° 43°
Corsair HX750W 750Watt 3,38V 4,99V 12,07V 91% 26,5° 41,5°
Corsair HX850W 850Watt 3,32V 5,01V 12,02V 91,5% 29° 41,5°
Corsair HX1000W 1000Watt 3,36V 5,05V 12,07V 86,5% 39,5° 50,5°
Enermax ECO80+ 350Watt 3,26V 4,96V 12,03V 85,5% 32° 43,5°
Enermax MaxRevo 1350Watt 3,32V 5,02V 12,06V 92,1% 28,3° 41,6°
Enermax Modu82+ 625Watt 3,32V 5,04V 12,11V 86,5% 33° 43,5°
Enermax Platimax 750Watt 3,33V 4,98V 12,09V 94,1% 28,1° 40,8°
Enermax Pro82+ 385Watt 3,33V 5,02V 12,05V 85,5% 34° 44,5°
Enermax Pro82+ II 425Watt 3,27V 4,90V 12,03V 86,6% 28,7° 42,2°
Enermax Pro87+ 500Watt 3,35V 5,07V 12,09V 91,7% 31,5° 42,5°
Enermax Modu87+ 700Watt 3,32V 5,04V 12,09V 91,9% 31,9° 42,3°
Enermax Revolution 85+ 850Watt 3,30V 4,99V 12,03V 90% 31,5° 39,5°
Enermax Triathlor 385Watt 3,32V 5,02V 12,16V 88,8% 28,4° 42,9°
FSP Aurum 400Watt 3,34V 5,08V 12,16V 91,4% 33,1° 41,1°
NZXT Hale Power 90+ 750Watt 3,31V 5,02V 11,95V 92,8% 31,2° 44,1°
OCZ Fatal1ty Series 700Watt 3,31V 4,99V 12,03V 86% 33,5° 44,5°
Scythe Stronger Plug-in 500Watt 3,34V 4,91V 11,96V 85,8% 31,6° 40,4°
Seasonic G-360 360Watt 3,34V 5.05V 12,16V 91,1% 32,2° 43,1°
Seasonic M12D 850Watt 3,32V 4,88V 12,05V 89% 30,5° 41,5°
Seasonic X-460 Fanless 460 Watt 3,34V 4,99V 12,15V 92,6% 30,7° 43,3°
Seasonic X-560 560 Watt 3,34V 5,00V 12,17V 92,9% 34,6° 39,2°
Seasonic X-750 750Watt 3,37V 5,04V 12,17V 93,1% 38,5° 36°
Seasonic Platinum 660Watt 3,31V 5,03V 12,06V 94,3% 31,1° 40,1°
Seasonic Platinum 860Watt 3,32V 5,00V 12,05V 94,6% 31,6° 40,6°
Sharkoon Rush Power 500Watt 3,30V 4,91V 11,88V 85,5% 33,5° 42,5°
Silver Power SP-S460FL 460Watt 3,33V 5,00V 12,15V 92,9% 30,8° 43,6°
Silver Power SP-SS400 400Watt 3,29V 4,86V 12,02V 85,5% 33° 42,5°
Silver Power SP-SS500 500Watt 3,31V 4,90V 11,99V 86,5% 33° 43,5°
Silver Power SP-SS650 650Watt 3,29V 4,92V 11,99V 85,5% 32,5° 44°
Silver Power SP-SS750M 750Watt 3,35V 5,07V 12,06V 89,7% 32° 39,5°
Silverstone Element ST60EF 600Watt 3,29V 4,98V 12,03V 86,5% 31,5° 42,5°
Silverstone Nightjar ST45NF 450Watt 3,30V 5,12V 12,15V 84,5% 45° 57,5°
Tagan TG680-U33II Piperock II 680 Watt 3,33V 5,03V 12,07V 87% 31,5° 42,5°
Tagan TG500-U33II SuperRock 500 Watt 3,32V 5,02V 12,14V 86,5% 31,5° 42,5°
Tagan TG680-U33II SuperRock 680 Watt 3,38V 5,02V 12,18V 87,5% 32,5° 43,5°
Xigmatek Go Green 500 Watt 3,33V 4,97V 12,15V 87% 34° 53,5°
Zalman ZM660-XT 660 Watt 3,29V 5,07V 11,99V 88% 32,5° 42°
Netzteil dBA-Idle (20%) dBA-Last (100%) Standby-Verbrauch (S5) Preis
Antec High Current Gamer 400Watt 19,1 dBA 33,4 dBA 0,46 Watt 57 €
Arctic Cooling Fusion 550R 500 Watt 17,5 dBA 23,5 dBA 0,5 Watt 59,90 €
be quiet! Straight Power E8 400 Watt 13,1 dBA 20,7 dBA 0,51 Watt 55 €
be quiet! Straight Power E9 400 Watt 14,3 dBA 20,6 dBA 0,19 Watt 63 €
be quiet! P8 Dark Power Pro 750Watt 22,5 dBA 33,5 dBA 0,69 Watt 135 €
be quiet! P10 Dark Power Pro 550Watt 13,9 dBA 17,8 dBA 0,21 Watt 115 €
Compucase Cougar 700CM 700Watt 22,5 dBA 32 dBA 0,95 Watt 119,90 €
Compucase Cougar S700 700Watt 17,5 dBA 27,5 dBA 0,73 Watt 135 €
Compucase Cougar SE400 400Watt 23,8 dBA 32,9 dBA 0,71 Watt 65 €
Cooler Master Silent Pro M-Series 600Watt 19 dBA 27,5 dBA 1,15 Watt 99,90 €
Corsair AX850 850Watt 0 dBA 34,5 dBA 0,46 Watt 165 €
Corsair CX400W 400Watt 19,5 dBA 27 dBA 0,8 Watt 49 €
Corsair HX450W 450Watt 18 dBA 26,5 dBA 0,35 Watt 80 €
Corsair HX650W 650Watt 19,5 dBA 30,5 dBA 0,88 Watt 100 €
Corsair HX750W 750Watt 26,5 dBA 35 dBA 0,77 Watt 120 €
Corsair HX850W 850Watt 26 dBA 35,5 dBA 0,8 Watt 159,90 €
Corsair HX1000W 1000Watt 25,5 dBA 38,5 dBA 1,6 Watt 170 €
Enermax ECO80+ 350Watt 17,5 dBA 25 dBA 0,63 Watt 45 €
Enermax MaxRevo 1350Watt 26,1 dBA 29,8 dBA 0,31 Watt 270 €
Enermax Modu82+ 625Watt 18,5 dBA 28,5 dBA 0,95 Watt 129 €
Enermax Platimax 750Watt 22,2 dBA 31,3 dBA 0,21 Watt 175 €
Enermax Pro82+ 385Watt 17,5 dBA 26,5 dBA 0,85 Watt 59 €
Enermax Pro82+ II 425Watt 22,3 dBA 34,5 dBA 0,88 Watt 65 €
Enermax Pro87+ 500Watt 13,5 dBA 19,5 dBA 0,54 Watt 119 €
Enermax Modu87+ 700Watt 14,5 dBA 20,5 dBA 0,67 Watt 155 €
Enermax Revolution 85+ 850Watt 18 dBA 31,5 dBA 0,85 Watt 240 €
Enermax Triathlor 385Watt 18,1 dBA 32,8 dBA 0,21 Watt 60 €
FSP Aurum 400Watt 17,1 dBA 37,1 dBA 0,29 Watt 65 €
NZXT Hale Power 90+ 750Watt 20,5 dBA 27 dBA 0,61 Watt 149,90 €
OCZ Fatal1ty Series 700Watt 20,5 dBA 29,5 dBA 0,76 Watt 119,90 €
Scythe Stronger Plug-in 500Watt 12,5 dBA 25,5 dBA 0,89 Watt 55 €
Seasonic G-360 360Watt 16,4 dBA 34,4 dBA 0,19 Watt 60 €
Seasonic M12D 850Watt 18 dBA 33,5 dBA 0,6 Watt 199 €
Seasonic X-460 Fanless 0 dBA 0 dBA 0,29 Watt 145 €
Seasonic X-560 560 Watt 0 dBA 33,5 dBA 0,39 Watt 130 €
Seasonic X-750 750Watt 0 dBA 33,5 dBA 0,51 Watt 155 €
Seasonic Platinum 660Watt 15,6 dBA 28,6 dBA 0,17 Watt 135 €
Seasonic Platinum 860Watt 16,3 dBA 32,8 dBA 0,14 Watt 210 €
Sharkoon Rush Power M 500Watt 16,5 dBA 26,5 dBA 0,93 Watt 53 €
Silver Power SP-S460FL 460Watt 0 dBA 0 dBA 0,23 Watt 105 €
Silver Power SP-SS400 400Watt 19,5 dBA 27,5 dBA 0,75 Watt 59 €
Silver Power SP-SS500 500Watt 19 dBA 29,5 dBA 0,8 Watt 79 €
Silver Power SP-SS650 650Watt 18 dBA 31 dBA 1,15 Watt 85 €
Silver Power SP-SS750M 650Watt 18,5 dBA 32,5 dBA 0,64 Watt 119 €
Silverstone Element ST60EF 600Watt 19,5 dBA 29 dBA 0,6 Watt 85 €
Silverstone Nightjar ST45NF 450Watt 0 dBA 0 dBA 1,25 Watt 145 €
Tagan TG680-U33II Piperock II 680 Watt 18 dBA 29 dBA 0,7 Watt 129 €
Tagan TG500-U33II SuperRock 500 Watt 19 dBA 28,5 dBA 0,55 Watt 60 €
Tagan TG680-U33II SuperRock 680 Watt 18,5 dBA 30,5 dBA 0,65 Watt 90 €
Xigmatek Go Green 500 Watt 19,5 dBA 29,5 dBA 0,76 Watt 59,90 €
Zalman ZM660-XT 660 Watt 18 dBA 24,5 dBA 0,93 Watt 159,90 €
08.12.2008 16:25 Cerberus is online Homepage of Cerberus Search for Posts by Cerberus Add Cerberus to your Buddy List
