SSDs: wichtige Firmware und Treiber Updates |
kongaless
Herkunft: Tübingen
Kingston hat eine neue Firmware für seine Sandforce SF-2281 Laufwerke online gestellt
klick
Release Notes for SH103S3, Firmware Rev. 503 (08/22/12):
• Restored a minor TRIM performance variation from a previous Firmware release
• Fixed a power management condition where the device failed to respond to a COMWAKE,
which might have resulted in the SSD becoming unresponsive thereby requiring a reset by the
host
25.08.2012 13:28 |
hello
für die Crucial m4 SSD gibt es eine neue Firmware
Revision Firmware 010G for the 2.5 inch m4 and 01MG for the Crucial mSATA are now available. If you are updating the firmware on the Crucial Adrenaline drive, you must uninstall the dataplex software before attempting the firmware update. Also, you can not use version 010G to update the Crucial mSATA, or 01MG to update the Crucial 2.5 inch m4. Please visit the following link to download this firmware update:
http://www.crucial.com/support/firmware.aspx
Release Date: 09/25/2012
Firmware for the Crucial m4 2.5” SSD is being updated from version 000F to 010G.
The m4 is updatable to this new firmware starting from any previous version in a single step.
This is an OPTIONAL update for any drive in the field. It is only recommended if the end user is experiencing an issue related to the following items.
Do NOT use any other m4 firmware update for your 2.5” SSD such as the 01MG firmware for the mSATA form factor.
Version 010G includes the following changes:
Improved Trim response time
Improved power-on-to-ready time (known as POR, or TTR for Time-to-ready)
Improved resume-time from low power modes, and improved reliability of warm reboot
Improved power consumption by disabling HIPM (Host Initiated Power Management)
Additional details can be found in the firmware guide |
so long
27.09.2012 02:13 |
slavakk
eben upgedatet
lief sehr geschmeidig, keine Probleme bisher
30.09.2012 17:45 |
Radommi
Herkunft: Köln
man liest teilweise davon, das sich die Crucial m4 nach dem neuesten Firmware Update aus dem System verabschiedet
die vorherige 000F Firmware gibts noch hier
18.10.2012 19:00 |
Trippsel
Herkunft: Dunkeldeutschland
für mein System kann ich das nicht bestätigen, keine Probleme mit der m4 und der neuen FW
hoffentlich bleibts so
19.10.2012 14:27 |
kongaless
Herkunft: Tübingen
einige haben wohl Probleme mit der neuen FW, aber andere nicht und nicht jeder der keine Probleme hat, schreibt das auch ins Netz
abwarten und zurücklehnen
20.10.2012 16:24 |
Tankred
SSD-Spezie
21.10.2012 16:02 |
Trippsel
oh mann
soll ich lieber gleich zur vorherigen FW zurück?
22.10.2012 16:52 |
kongaless
Herkunft: Tübingen
eine neue Crucial M4 Firmware ist fast fertig
Quelle
16.11.2012 19:54 |
slinx
Herkunft: Hannover
für Intels 335 SSD gibts ein Firmware Update wegen der falschen Anzeige der Media Wear Indicators (MWI) in einigen SSD Tools, also der Lebensdaueranzeige
klick
__________________ >keine Toleranz gegenüber Intoleranz<
30.11.2012 14:23 |
kongaless
Herkunft: Tübingen
Plextor M5 Pro Firmware Update |
die Plextor M5 Pro bekommt eine neue Firmware
hier sollte sie nächste Woche online sein
05.12.2012 13:48 |
slinx
Herkunft: Hannover
14.12.2012 14:35 |
Jabberwocky
Herkunft: Heidelberg
die FW hat Cerberus in seinem 840er Test noch erwähnt
14.12.2012 20:14 |
zetmarker
21.02.2013 01:13 |
kongaless
Herkunft: Tübingen
was verbessert wurde:
- Trim operation efficiency
- Data error recovery capability
- Drive stability under heavy loading
21.02.2013 22:25 |
couchplaner
Herkunft: Wiesbaden
bei OCZ gibts ein Update mit Updatetool usw. für die Vector SSD
OCZ Vector 1.03.1
scheint das erste Update zu sein
ein Changelog find ich nicht
27.02.2013 14:14 |
kongaless
Herkunft: Tübingen
Improvements since version 1.03: This firmware release only has optimizations for manufacturing with no end user facing impact |
betrifft also den Verbraucher nicht, ist wohl eine verbesserte Werks Firmware mit der die dann ausgeliefert werden
28.02.2013 15:51 |
couchplaner
Herkunft: Wiesbaden
oh
dann ignoriert bitte meinen Text
06.03.2013 17:16 |
slinx
Herkunft: Hannover
OCZ hat eine neue Firmware v2.0 für die Vector SSD fertig
21.03.2013 20:45 |
zetmarker
03.04.2013 15:17 |
