Predator2X
ich habe mal ein wenig gegoogelt und hab ein bissle in einem englisch geschriebenem thread gelesen, das man diesen Treiber >Hier<
nehmen sollte.
hier noch ein kleiner text dazu:
download and install on your system. Please Ignore any warning message while installating the drivers. Restart the system after installing the driver and disconnect other external devices like Printer, Scanner & external zip drive, disable anti-virus, then connect the Reader directly to USB port on the back of the computer with the card in it, then check for a Removable Disk icon under "My Computer". Check by connecting to all USB ports.
Note: These drivers are tested in our lab and many of the customer uisng successfully on windows XP, but they are not yet certified.When the systems warns about the Logo Certification, you can continue the installation procedure.This WILL NOT do any harm to your system.
hoffe das hilft weiter.
Gruss Pred
