PC-Experience » Software Foren: » Windows 9x, NT, 2000, XP: » Blauer Bildschirm (mal wieder) » Hallo Gast [Anmelden|Registrieren]
Zum Ende der Seite springen Blauer Bildschirm (mal wieder)
venom138
traurig Blauer Bildschirm (mal wieder) Auf diesen Beitrag antworten Zitatantwort auf diesen Beitrag erstellen Diesen Beitrag editieren/löschen Diesen Beitrag einem Moderator melden       Zum Anfang der Seite springen
Hallo! Mein PC crasht permanent, vielleicht könnt ihr mir weiterhelfen, RAM-Fehler schließe ich aus. Hier mal der Dump von heute und von gestern.
Microsoft (R) Windows Debugger Version 6.2.0013.1
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini042504-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows XP Kernel Version 2600 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt
Built by: 2600.xpsp2.030422-1633
Kernel base = 0x804d4000 PsLoadedModuleList = 0x8054a230
Debug session time: Sun Apr 25 23:14:18 2004
System Uptime: 0 days 0:01:14.267
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, bf8474c3, f360f56c, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : Unknown_Image ( win32k+474c3 )
Followup: MachineOwner
Loading Dump File [C:\WINDOWS\Minidump\Mini042604-01.dmp]
Product: WinNt
Debug session time: Mon Apr 26 15:50:09 2004
System Uptime: 0 days 3:51:02.742
BugCheck 1000008E, {c0000005, 80538160, f3a0ea88, 0}
Unable to load image \??\C:\Programme\Norton SystemWorks 2004 Pro\Norton Antivirus\SAVRT.SYS, Win32 error 2
*** WARNING: Unable to verify timestamp for SAVRT.SYS
*** ERROR: Module load completed but symbols could not be loaded for SAVRT.SYS
Probably caused by : Unknown_Image ( nt!ExFreePool+b )
26.04.2004 16:14 venom138 ist offline E-Mail an venom138 senden Beiträge von venom138 suchen Nehmen Sie venom138 in Ihre Freundesliste auf
Heaven Heaven ist weiblich
Hallo venom138,
und willkommen bei PC-Experience :)).
Fährt der PC immer in den Bluescreen? Auch im abgesicherten Modus, bzw in der letzten als funktionierend bekannten Konfiguration?
Hast du schon mal eine Reparatur von XP probiert? Eine Anleitung dazu findest du hier .
26.04.2004 16:38 Heaven ist offline E-Mail an Heaven senden Homepage von Heaven Beiträge von Heaven suchen Nehmen Sie Heaven in Ihre Freundesliste auf
venom138
Themenstarter Thema begonnen von venom138
im abgesicherten Modus hatte ich den noch nicht, bislang gings auch gut, gestern abend 2mal abgesoffen und heute eben. Ich hab mal die Auslagerungsdatei wieder auf c: gepackt und Norton deaktiviert. Ansonsten bin ich eher davon überzeugt, dass mein System i.o. ist, zuviel Müll hab ich auch nicht drauf, überflüssige programme auch nicht.
durch die Troubleshootings (übrigens sehr hilfreich) hab ich mich schon gewühlt, aber ohne Ergebnis.
Schon wieder nen Crash:
BugCheck D1, {424d240, 2, 0, f1fca72d}
Unable to load image \SystemRoot\system32\drivers\smwdm.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for smwdm.sys
*** ERROR: Module load completed but symbols could not be loaded for smwdm.sys
Unable to load image \SystemRoot\system32\drivers\kmixer.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for kmixer.sys
*** ERROR: Module load completed but symbols could not be loaded for kmixer.sys
Probably caused by : Unknown_Image ( kmixer+172d )
Dieser Beitrag wurde 1 mal editiert, zum letzten Mal von venom138: 26.04.2004 17:00.
26.04.2004 16:51 venom138 ist offline E-Mail an venom138 senden Beiträge von venom138 suchen Nehmen Sie venom138 in Ihre Freundesliste auf
Die gerade aufgeführten Treiberdateien klingen mir nach der Soundkarte. Entferne die mal in der Systemsteuerung und installier den neuesten Treiber.
26.04.2004 18:45 Heaven ist offline E-Mail an Heaven senden Homepage von Heaven Beiträge von Heaven suchen Nehmen Sie Heaven in Ihre Freundesliste auf
venom138
Hab jetzt kurzen Prozess gemacht und Win. neu installed, mitsamt neuen Treibern. die blauen Bildschirme kamen sogar beim Reparieren!! Ich hoffe der Mist läuft jetzt...
26.04.2004 20:21 venom138 ist offline E-Mail an venom138 senden Beiträge von venom138 suchen Nehmen Sie venom138 in Ihre Freundesliste auf
Ich hatte den "Symbols"-Bluescreen-Fall neulich an einem Kunden-PC, da schlugen leider auch jegliche Reparaturversuche fehl und das Resultat war eine Neuinstallation.
Ich hoffe es läuft jetzt zufriedenstellend bei dir, und close den Thread. Falls du die gleichen Probleme wieder haben solltest: PM an mich, dann öffne ich wieder.
26.04.2004 20:32 Heaven ist offline E-Mail an Heaven senden Homepage von Heaven Beiträge von Heaven suchen Nehmen Sie Heaven in Ihre Freundesliste auf
venom138
und da bin ich wieder :(
BugCheck 50, {f000ef5d, 1, bf87b61c, 0}
Unable to load image \SystemRoot\System32\win32k.sys, Win32 error 2
Probably caused by : Unknown_Image ( win32k+7b61c )
BugCheck D1, {145, 2, 0, f746b337}
Unable to load image \SystemRoot\System32\DRIVERS\USBPORT.SYS, Win32 error 2
*** WARNING: Unable to verify timestamp for USBPORT.SYS
*** ERROR: Module load completed but symbols could not be loaded for USBPORT.SYS
Probably caused by : Unknown_Image ( USBPORT+15337 )
Ich war vorhin mal kurz weg, und als ich wiederkam, machte der PC urlaute Geräusche, noch nie gehört sowas. Ich habe jetzt einen 512RAM-Baustein rausgenommen und bisher läuft der PC i.o., aber alle RAM-Tests waren positiv, zumal ich den Rechner jetzt schon 4 Wochen hab.
27.04.2004 14:42 venom138 ist offline E-Mail an venom138 senden Beiträge von venom138 suchen Nehmen Sie venom138 in Ihre Freundesliste auf
B@dman B@dman ist männlich
Hast du mal die Platte mit dem DriveFitnessTest gecheckt?
Was waren das für Geräusche? Quietschen, Klacken, Schleifen,...?
27.04.2004 14:56 B@dman ist offline Homepage von B@dman Beiträge von B@dman suchen Nehmen Sie B@dman in Ihre Freundesliste auf
venom138
Wenn ich DAS Geräusch mal beschreiben könnte...
Also der Rechner läuft jetzt2h auf 512 RAM ohne probleme, war grad beim händler RAM testen und der war Tatsache defekt. Ich baue den neuen gleich mal ein und bin überzeugt der läuft dann auch.... oki e
2 Tage wieder für nichts geopfert... :wand
ICh danke euch für eure Hilfe trotzdem! juhu
27.04.2004 16:27 venom138 ist offline E-Mail an venom138 senden Beiträge von venom138 suchen Nehmen Sie venom138 in Ihre Freundesliste auf
