Probleme mit 2560MB RAM |
Auri
Registration Date: 12.01.2004
mein Index lag bisher bei 4,9 (ca 2 Monate her).
Heute hatte ich dann mal neu getestet und kam nur auf 2,5. Ursache ist der Punkt RAM.
Speicher ist 2559 MB RAM.
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 3800+
Codename Manchester
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Package Socket 939
CPUID F.B.1
Extended CPUID F.2B
Brand ID 5
Core Stepping BH-E4
Technology 90 nm
Core Speed 2006.3 MHz (10.0 x 200.6 MHz)
HT Link speed 1003.1 MHz
Stock frequency 2000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 10.0x
VID range 1.100 V - 1.400 V
Features XD
K8 Thermal sensor yes
K8 Revision ID 4.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Chipset
Northbridge NVIDIA SPP100 (C51D) rev. A2
Southbridge NVIDIA nForce4 MCP rev. A4
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 2560 MBytes
Channels Single
Memory Frequency 100.3 MHz (CPU/20)
CAS# 2.5
RAS# to CAS# 2
RAS# Precharge 2
Cycle Time (tRAS) 5
Bank Cycle Time (tRC) 7
DRAM Idle Timer 16
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 1024 MBytes
Max bandwidth PC3200 (200 MHz)
Part number CMX1024-3500LLPRO
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200
CAS# 2.0
RAS# to CAS# delay 3
RAS# Precharge 2
TRAS 6
DIMM #2
General
Memory type DDR
Size 512 MBytes
Part number CMX512-3200C2PRO
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Timings table
Frequency (MHz) 200
CAS# 3.0
RAS# Precharge 3
TRAS 8
DIMM #3
General
Memory type DDR
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Mehr: http://auri.fileave.com/cpuz.htm
Ich möchte zu einem natürlich die Performance verbessern, zum anderen weiß ich nicht, warum der Wert so schlecht ist. Tage zuvor hatte ich beim Runterfahren auch eine ram.dump.
Auri
Edit by Admin: künftig bitte aussagekräftigere Topics schreiben !
16.03.2008 16:32 |
Konkoni
Registration Date: 24.12.2005
der Thread sollte mal bitte in Arbeitsspeicher verschoben werden
dein Problem ist nicht der Leistungsindex von Vista, sondern deine RAM Bestückung
du hast 3 Module eingesetzt, damit ist Dualchannel auf dem Chipsatz (nForce 4) schon mal futsch, du hast nur noch Singlechannel und das kostet dich mindestens 5% Performance
nimm das 512er Modul raus, dann paßt es wieder
16.03.2008 16:59 |
Auri
Thread Starter
OK, werde ich nachher machen und erneut testen. Heißt das also, dass ich noch einen
weiteres RAM Modul einsetzen muss?? Also nochmals 512 MB und dann wäre der Dualchannel wieder erreicht??
Auri
16.03.2008 17:49 |
Konkoni
ja aber nur theoretisch
denn Vollbestückung auf einem Sockel 939 Mainboard ist reine Glückssache und funktioniert meistens garnicht
16.03.2008 18:13 |
Auri
Thread Starter
OK, werde ich wohl mal an meiner Hardware arbeiten müssen :)
Danke. Kann dann geschlossen werden.
Auri
16.03.2008 18:53 |
wir danken Konkoni und heften das Thema ab
17.03.2008 00:15 |
