PC-Experience » Hardware Foren : » Mainboards : » Inf Dateien für Mainboard manuel aus einer Setup.exe entpacken per "manual command line Flags" » Hello Guest [Login|Register]
Go to the bottom of this page Inf Dateien für Mainboard manuel aus einer Setup.exe entpacken per "manual command line Flags"
ArGuS $posts[username] is a male
Registration Date: 28.07.2003
Herkunft: Mühlheim am Main
Inf Dateien für Mainboard manuel aus einer Setup.exe entpacken per "manual command line Flags" Reply to this Post Post Reply with Quote Edit/Delete Posts Report Post to a Moderator       Go to the top of this page
Hallo liebe PC-E Gemeinde.
Ich habe da ein kleine Problemchen.
Ich hab eine Setup Datei mit Chipsatzdateien vorliegen. Wenn ich die Exe per Winrar entpacken tue, sind nur die .cat Dateien enthalten, jedoch keine .inf Dateien. Dann hab ich mal im Readme gelesen und da steht folgendes:
* 4. LIST OF AVAILABLE COMMAND LINE FLAG OPTIONS
The Intel(R) Chipset Software Installation Utility supports
several command line flags for various installation options.
All command line flags and parameters must be separated by a
space, except for the language code after the '-L' flag.
Due to the different distribution formats available for the
Intel(R) Chipset Software Installation Utility, the command
line flag syntax may vary:
1. Self-Extracting .EXE Distribution:
When installing this software using the .EXE
distribution, an extra '-A' must be appended to the
INFINST_xxx.EXE program call (i.e. INFINST_ENU.EXE -A)
in order to successfully pass command line flags.
NOTE: The extra '-A' flag for the self-extracting .EXE
package is different from the '-A' command line flag
option described under Compressed .ZIP Distribution.
Example: To extract INF files using the '-A' flag
described below, the installation program
should be invoked as follows:
INFINST_ENU.EXE -A -A (optional -P)
2. Compressed .ZIP Distribution:
When installing this software using the .ZIP distribution,
use the command line flags exactly as discribed below.
SETUP.EXE -A (optional -P)
Below is a list of all the available command line flags that
may be used with the program call. Note that the '-L' and
the '-S' flags MUST be specified at the end of the command
line flag list.
Flag Description
-A Extracts the INF files and Readme to either
"C:\Program Files\Intel\InfInst" or the
<Installation Path> directory specified using
the '-P' flag. The software will NOT install
these INF files to the system. This flag can
be combined only with the '-P' flag. All other
options will be ignored if the '-A' flag is
specified. This flag works in either Silent
Mode or Interactive Mode.
-L<LangCode>
Forces the InstallShield* user interface to
display the specified language during setup.
Note that there should be NO spaces between
'-L' and the 4-digit language code (see below).
This flag and the '-S' flag must be placed at
the end of the command line flag list. This
flag works in Interactive Mode only.
-NOLIC
Disables the license agreement dialog box during
installation. This parameter works in Interactive
Mode only.
-P <Installation Path>
Specifies the hard disk location to which the
INF program files are copied. If this flag is
not specified at the command line, the
<Installation Path> directory is as follows:
C:\Program Files\Intel\INFInst
If this flag is used without the '-A' option,
only the Readme will be copied to
<Installation Path>. The directory name can
include spaces, but then a pair of double quotes
(") must enclose the directory name. This flag
works in either Silent Mode or Interactive Mode.
-S Runs the Installer in Silent Mode (no user
interface is displayed). This flag and the
'-L' flag must be placed at the end of the
Below are the language codes used with the '-L' flag:
Language <LangCode>
German 0007
Ich möchtel also wie oben beschrieben die .inf Dateien mit den .cat Dateien in ein seperates Verzeichnis entpacken lassen. Da ich davon leider 0 Plan hab wie ich das machen soll mit den Befehlen, wende ich mich hiermit an die Profis unter euch. Wie sieht denn jetz der genaue Befehl in der cmd aus?
Das hier habe ich selber schon versucht, aber ohne erfolg:
1.) infinst_autol.exe -A -A -P
2.) infinst_autol.exe -A -A -P d:\Treiber\infintel
Ich hoffe Ihr könnt mir helfen, da ich mit meinem Latein am Ende bin.
Schönes Pfingstfest.
ArGuS
Mein System bei Nethands.
Bei Anruf: Moor ;-))
This post has been edited $posts[editcount] time(s), it was last edited by $posts[editor] on 15.05.2005 10:21.
15.05.2005 10:11 ArGuS is offline Send an Email to ArGuS Search for Posts by ArGuS Add ArGuS to your Buddy List
Joinie $posts[username] is a male
Registration Date: 25.04.2005
warum?
was gefällt dir denn an der Setuproutine nicht?
p.s. wenn du den 4.30.1006 entpackst, ist auch eine Readme dabei mit den Command Line Flag Options
15.05.2005 10:59 Joinie is offline Search for Posts by Joinie Add Joinie to your Buddy List
das hat nichts mit gefallen zu tun.
Ich möchte mir eine Unattended Installation erstellen und da benötigt man nun mal INF Dateien :D
Aber der Thread hat sich erledigt.
Hab es hinbekommen.
Hatte lediglich ein -A zuviel Augenzwinkern
Danke trotzdem.
15.05.2005 12:03 ArGuS is offline Send an Email to ArGuS Search for Posts by ArGuS Add ArGuS to your Buddy List
warum schreibst du das nicht in deine Eingangsfrage???
ohne Informationen geht die Antwort selten in die richtige Richtung...
15.05.2005 12:05 Cerberus is offline Homepage of Cerberus Search for Posts by Cerberus Add Cerberus to your Buddy List
